smbc.aufo events
smbc.aufo.completed
- Severity
NOTICE
 - Description
This message occurs when the SnapMirror® Business Continuity (SMBC) automatic unplanned failover operation completes.
 - Corrective Action
(None).
 - Syslog Message
SnapMirror automatic failover completed. Destination path: %s.
 - Parameters
dstpath (STRING): Path name of the destination group of the SMBC relationship.
smbc.aufo.failed
- Severity
ERROR
 - Description
This message occurs when the SnapMirror® Business Continuity (SMBC) automatic unplanned failover operation fails.
 - Corrective Action
Perform "snapmirror delete -destination-path destination_path" followed by "snapmirror break" on the volumes.
 - Syslog Message
SnapMirror automatic failover failed. Destination path: %s.
 - Parameters
smbc.aufo.failover.incapable
- Severity
ERROR
 - Description
This message occurs when the SnapMirror® Business Continuity (SMBC) automatic unplanned failover operation fails because the destination site is not failover capable.
 - Corrective Action
Before applying corrective action, the User must ensure that the primary/master copy is unavailable, otherwise the assumption is that Master copy is actively being used by the Application workload. Perform "snapmirror delete -destination-path destination_path" followed by "snapmirror break" on the volumes.
 - Syslog Message
SnapMirror automatic failover encountered a failure because the site with destination path "%s" is not failover-capable.
 - Parameters
smbc.aufo.io.outage.complete
- Severity
NOTICE
 - Description
This message occurs when I/O can resume after an automatic unplanned failover of a SnapMirror Business Continuity (SMBC) relationship.
 - Corrective Action
(None).
 - Syslog Message
In the automatic unplanned failover of the SMBC relationship with destination path %s and relationship-ID %s, I/O disruption started at %s and lasted for %u msecs. Mediator Agent processing started at %s and lasted for %u msecs.
 - Parameters
dstpath (STRING): Destination path of the SMBC relationship.
cg_rel_id (STRING): ID of the SMBC relationship.
io_outage_start_time (STRING): I/O disruption start time.
io_outage_latency (LONGINT): I/O disruption window (msecs).
tba_trigger_start_time (STRING): Mediator Agent processing start time.
tba_trigger_latency (LONGINT): Mediator Agent processing window (msecs).
smbc.aufo.queued
- Severity
NOTICE
 - Description
This message occurs when the SnapMirror® Business Continuity (SMBC) automatic unplanned failover operation is queued.
 - Corrective Action
(None).
 - Syslog Message
SnapMirror Business Continuity (SMBC) automatic unplanned operation failover queued. Destination path: %s.
 - Parameters
smbc.aufo.start
- Severity
NOTICE
 - Description
This message occurs when the SnapMirror® Business Continuity (SMBC) automatic unplanned failover operation starts.
 - Corrective Action
(None).
 - Syslog Message
SnapMirror automatic failover started. Destination path: %s.
 - Parameters
