ONTAP EMS reference
sis.schedule events
sis.schedule EMS events occur when ONTAP encounters issues associated with Single Instance Storage (SIS) schedules.
sis.schedule.notify.change
Severity
NOTICE
This message occurs when the Single Instance Storage (SIS) schedule of a volume is changed to the default schedule (sun-san@0) because the node's clusterid does not match with the SIS config clusterid. This can happen when a volume is replicated to a node belonging to another cluster.
Corrective Action
Use the sis config command to set a SIS policy on the volume.
Syslog Message
SIS policy for volume %s%s is no longer valid because of the clusterid mismatch. SIS schedule is set to the default schedule sun-sat@0.
volume (STRING): Volume name.
volident (STRING): To uniquely identify the volume in cases where volume name itself is insufficient.
sis.schedule.notify.change.compression
Severity
NOTICE
This message occurs when a volume with background compression has an auto type policy. The policy is replaced with a default schedule (sun-sat@0). This can happen when a volume is being re-mounted during which efficiency policy type is changed to auto.
Corrective Action
Use the volume efficiency modify command to set a efficiency policy on the volume. For example: volume efficiency modify -volume volume-name -policy policy-name
Syslog Message
Efficiency policy for volume %s%s is auto type and is not supported with background compression. The schedule is set to the default schedule sun-sat@0.
sis.schedule.notify.change.snapmirror
Severity
NOTICE
This message occurs when a SnapMirror® relationship spanning across Vservers breaks. In such cases, the efficiency policy on the destination is no longer valid; it is replaced with the default schedule (sun-sat@0).
Corrective Action
Use the 'volume efficiency modify' command to set a efficiency policy on the volume. For example: volume efficiency modify -volume volume-name -policy policy-name
Syslog Message
Efficiency policy for volume %s%s is not valid and has been replaced with default schedule (sun-sat@0).
