sis.schedule events
sis.schedule EMS events occur when ONTAP encounters issues associated with Single Instance Storage (SIS) schedules.
sis.schedule.notify.change
- Severity
NOTICE
- Description
This message occurs when the Single Instance Storage (SIS) schedule of a volume is changed to the default schedule (sun-san@0) because the node's clusterid does not match with the SIS config clusterid. This can happen when a volume is replicated to a node belonging to another cluster.
- Corrective Action
Use the sis config command to set a SIS policy on the volume.
- Syslog Message
SIS policy for volume %s%s is no longer valid because of the clusterid mismatch. SIS schedule is set to the default schedule sun-sat@0.
- Parameters
volume (STRING): Volume name.
volident (STRING): To uniquely identify the volume in cases where volume name itself is insufficient.
sis.schedule.notify.change.compression
- Severity
NOTICE
- Description
This message occurs when a volume with background compression has an auto type policy. The policy is replaced with a default schedule (sun-sat@0). This can happen when a volume is being re-mounted during which efficiency policy type is changed to auto.
- Corrective Action
Use the volume efficiency modify command to set a efficiency policy on the volume. For example: volume efficiency modify -volume volume-name -policy policy-name
- Syslog Message
Efficiency policy for volume %s%s is auto type and is not supported with background compression. The schedule is set to the default schedule sun-sat@0.
- Parameters
sis.schedule.notify.change.snapmirror
- Severity
NOTICE
- Description
This message occurs when a SnapMirror® relationship spanning across Vservers breaks. In such cases, the efficiency policy on the destination is no longer valid; it is replaced with the default schedule (sun-sat@0).
- Corrective Action
Use the 'volume efficiency modify' command to set a efficiency policy on the volume. For example: volume efficiency modify -volume volume-name -policy policy-name
- Syslog Message
Efficiency policy for volume %s%s is not valid and has been replaced with default schedule (sun-sat@0).
- Parameters
