telnet.setsockopt events
telnet.setsockopt.failure
- Severity
ERROR
- Description
This message occurs when setsockopt on telnet socket fails
- Corrective Action
Use the error code contained in this message to determine the problem.
- Syslog Message
Telnet setsockopt error: option %s, option value %s, error code %d (%s).
- Parameters
socketlevel (STRING): This is the socket option level parameter
socketoption (STRING): This is the socket option value parameter
errorcode (INT): This is the error code returned from setsockopt
reason (STRING): Reason why setsockopt failed on telnet socket.
