ONTAP EMS reference
hypervisor.guest events
hypervisor.guest EMS events occur when ONTAP encounters issues associated with the hypervisor configuration required to support an ONTAP® Select guest.
hypervisor.guest.cpu
Severity
ALERT
This message occurs when the hypervisor does not have a sufficient number of CPUs configured to support an ONTAP® Select guest.
Corrective Action
Configure the required number of CPUs in the hypervisor configuration to support an ONTAP® Select guest.
Syslog Message
Insufficient CPUs configured for the ONTAP® Select guest on the hypervisor: %d. %d CPUs are required.
count (INT): Number of CPUs currently configured.
required (INT): Required number of CPUs to be configured.
hypervisor.guest.guests
Severity
ALERT
This message occurs when the number of ONTAP® Select guests exceeds the recommended limit.
Corrective Action
Reduce the number of guests on the hypervisor to meet the requirements for ONTAP® Select.
Syslog Message
Unsupported number of ONTAP® Select guests on the hypervisor: %d. Maximum supported number of guests: %d.
count (INT): Number of ONTAP® Select guests.
required (INT): Maximum number of ONTAP® Select guests.
hypervisor.guest.if.count
Severity
ALERT
This message occurs when the hypervisor does not have a sufficient number of virtual network interfaces configured for the guest for ONTAP® Select support.
Corrective Action
Verify that enough virtual network interfaces are configured to meet the requirements for ONTAP® Select.
Syslog Message
Insufficient number of virtual network interfaces configured for the ONTAP® Select guest on the hypervisor: %d. %d interfaces are required.
count (INT): Number of virtual network interfaces configured.
required (INT): Required number of virtual network interfaces to be configured.
hypervisor.guest.if.speed
Severity
ALERT
This message occurs when the speed of the virtual network interface configured for the guest is not sufficient for ONTAP® Select support.
Corrective Action
Configured the speed of the virtual network interface to meet the required speed for ONTAP® Select support.
Syslog Message
The speed of interface %s configured for the ONTAP® Select guest on the hypervisor is insufficient: %s. Required speed: %s.
name (STRING): Name of the virtual network interface.
speed (STRING): Speed of the configured virtual network interface.
required (STRING): Required speed of virtual network interface to be configured.
hypervisor.guest.if.status
Severity
ALERT
This message occurs when a guest's virtual network interface is not operational.
Corrective Action
The interface, port, or cabling needs to be investigated for faults. The interface must be "up" to meet the requirements for ONTAP® Select.
Syslog Message
Virtual network interface %s assigned to the ONTAP® Select guest is not operational. Current status: %s.
status (STRING): Operational status of the virtual network interface.
hypervisor.guest.memory
Severity
ALERT
This message occurs when the hypervisor does not have a sufficient amount of memory configured for the guest for ONTAP® Select support.
Corrective Action
Configure the required amount of memory in the hypervisor configuration to support an ONTAP® Select guest.
Syslog Message
Insufficient amount of memory configured for the ONTAP® Select guest on the hypervisor: %s. Required memory: %s.
amount (STRING): Amount of memory configured.
required (STRING): Required amount of memory to be as configured.
