ONTAP EMS reference
rdb.sql events
rdb.sql.upgrade.failed
Severity
ERROR
This message occurs when the cluster management Data Replication Module could not upgrade its database from RDB to SQL.
Corrective Action
Contact Contact NetApp technical support. for assistance.
Syslog Message
Error: %s. Unable to upgrade the local database from RDB to SQL of Data Replication Module: %s.
message (STRING): Error message.
unit (STRING): Unit that failed the upgrade.
rdb.sql.upgrade.succeeded
Severity
NOTICE
This message occurs when the cluster management Data Replication Module upgrades its database from RDB to SQL.
Corrective Action
(None).
Syslog Message
Successful upgrade of the local database from RDB to SQL of Data Replication Module: %s. Duration: %s sec Tables: %llu Records: %llu
unit (STRING): Unit that finished the upgrade.
duration (STRING): Duration of the upgrade in seconds.
tables (LONGINT): Number of tables processed.
records (LONGINT): Number of records processed.
