ONTAP EMS reference
mgmtgwd.upgrade events
mgmtgwd.upgrade.aborted
Severity
ALERT
This message occurs when an upgrade task is aborted. The node will not be fully operational.
Corrective Action
(Call support).
Syslog Message
(None).
(None).
mgmtgwd.upgrade.failed
Severity
ALERT
This message occurs when one or more upgrade tasks fails. The node will not be fully operational.
Corrective Action
(Call support).
Syslog Message
(None).
(None).
mgmtgwd.upgrade.started
Severity
INFORMATIONAL
This message occurs when an upgrade is started.
Corrective Action
(None).
Syslog Message
(None).
(None).
mgmtgwd.upgrade.success
Severity
INFORMATIONAL
This message occurs when an upgrade is completed successfully.
Corrective Action
(None).
Syslog Message
(None).
(None).
Looking for answers?
Try Doc, our Gen AI Assistant.
