The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
mgmtgwd.upgrade events
Creating your file...
Your file is ready
mgmtgwd.upgrade.aborted
- Severity
ALERT
- Description
This message occurs when an upgrade task is aborted. The node will not be fully operational.
- Corrective Action
(Call support).
- Syslog Message
(None).
- Parameters
(None).
mgmtgwd.upgrade.failed
- Severity
ALERT
- Description
This message occurs when one or more upgrade tasks fails. The node will not be fully operational.
- Corrective Action
(Call support).
- Syslog Message
(None).
- Parameters
(None).
mgmtgwd.upgrade.started
- Severity
INFORMATIONAL
- Description
This message occurs when an upgrade is started.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
(None).
mgmtgwd.upgrade.success
- Severity
INFORMATIONAL
- Description
This message occurs when an upgrade is completed successfully.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
(None).
