mgmtgwd.upgrade events
Creating your file...
Your file is ready
mgmtgwd.upgrade.aborted
- Severity
ALERT
- Description
This message occurs when an upgrade task is aborted. The node will not be fully operational.
- Corrective Action
(Call support).
- Syslog Message
(None).
- Parameters
(None).
mgmtgwd.upgrade.failed
- Severity
ALERT
- Description
This message occurs when one or more upgrade tasks fails. The node will not be fully operational.
- Corrective Action
(Call support).
- Syslog Message
(None).
- Parameters
(None).
mgmtgwd.upgrade.started
- Severity
INFORMATIONAL
- Description
This message occurs when an upgrade is started.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
(None).
mgmtgwd.upgrade.success
- Severity
INFORMATIONAL
- Description
This message occurs when an upgrade is completed successfully.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
(None).
