      mgmtgwd.upgrade events
mgmtgwd.upgrade.aborted
- Severity
ALERT
 - Description
This message occurs when an upgrade task is aborted. The node will not be fully operational.
 - Corrective Action
(Call support).
 - Syslog Message
(None).
 - Parameters
(None).
mgmtgwd.upgrade.failed
- Severity
ALERT
 - Description
This message occurs when one or more upgrade tasks fails. The node will not be fully operational.
 - Corrective Action
(Call support).
 - Syslog Message
(None).
 - Parameters
(None).
mgmtgwd.upgrade.started
- Severity
INFORMATIONAL
 - Description
This message occurs when an upgrade is started.
 - Corrective Action
(None).
 - Syslog Message
(None).
 - Parameters
(None).
mgmtgwd.upgrade.success
- Severity
INFORMATIONAL
 - Description
This message occurs when an upgrade is completed successfully.
 - Corrective Action
(None).
 - Syslog Message
(None).
 - Parameters
(None).
