ONTAP EMS reference
adminapi.input events
adminapi.input.badXml
Severity
ERROR
This message occurs when the Data ONTAP server receives a bad XML request that does not contain the API name to be executed.
Corrective Action
Correct the input XML with the API name to be executed.
Syslog Message
Input XML does not contain the API name to be executed.
(None).
