adminapi.input events
Creating your file...
Your file is ready
adminapi.input.badXml
- Severity
ERROR
- Description
This message occurs when the Data ONTAP server receives a bad XML request that does not contain the API name to be executed.
- Corrective Action
Correct the input XML with the API name to be executed.
- Syslog Message
Input XML does not contain the API name to be executed.
- Parameters
(None).
