The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
snapvault.reg events
Creating your file...
Your file is ready
snapvault.reg.unknownOpt
- Severity
NOTICE
- Description
This message occurs when you downgrade from a kernel with newer version to one with an older version and the system attempts to read a registry entry that is supported only in the newer version of the kernel.
- Corrective Action
(None).
- Syslog Message
Unsupported registry entry: (%s).
- Parameters
regopt (STRING): Unrecognized registry entry for the older version of the kernel.
