ONTAP EMS reference
dbs.disconn events
dbs.disconn EMS events occur when ONTAP encounters issues associated with network connectivity between cluster pairs or remote nodes in the Distributed Block Store (DBS).
dbs.disconn.cluster.pair
Severity
ERROR
This message occurs when the distributed block store detects that a cluster pair is disconnected or configured incorrectly. The distibuted block store is responsible for managing the data that backs the flexible volumes.
Corrective Action
Check network connectivity between clusters. One of the clusters in the pair might have become misconfigured or disconnected. Remove the local pairing and retry pairing the clusters.
Syslog Message
The distributed block store detects that the cluster pair is disconnected or configured incorrectly. The cluster fault type is %s and fault id is %u.
cfType (STRING): Distibuted block store cluster fault type of the associated object.
cfID (INT): Distibuted block store cluster fault ID number associated with the fault.
cfStatus (INT): Current status of the cluster fault. 1 = New (just reported), 2 = Existing (updated), 3 = Resolved (closed).
cfDetails (STRING): Description of the cluster fault, including context details.
cfExtSrc (STRING): Distibuted block store cluster fault external source label created by the "CreateClusterFault" API command and attached to the fault for testing purposes.
dbs.disconn.remote.node
Severity
ERROR
This message occurs when the Distributed Block Store (DBS) detects that a remote node is not connected to cluster network. The DBS is responsible for managing the data that backs the FlexVols®.
Corrective Action
Ping the remote nodes using jumbo frames to test network connectivity.
Syslog Message
The Distributed Block Store has detected that a remote node is not connected to cluster network. The cluster fault type is %s and fault id is %u.
cfType (STRING): DBS cluster fault type of the associated object.
cfID (INT): DBS cluster fault ID number associated with the fault.
cfExtSrc (STRING): DBS cluster fault externalSource label created by the CreateClusterFault API command and attached to the fault for testing purposes.
