esh.unexpected events
Creating your file...
Your file is ready
esh.unexpected.status
- Severity
ALERT
- Description
This message occurs when a disk shelf reports an unknown status.
- Corrective Action
Ensure that the shelf module firmware and ONTAP® software are compatible versions. Find firmware versions at the NetApp technical support web site.
- Syslog Message
Unexpected ESH status of: %d.
- Parameters
status (INT): Unexpected/unknown status code that was received.
