The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
esh.unexpected events
Creating your file...
Your file is ready
esh.unexpected.status
- Severity
ALERT
- Description
This message occurs when a disk shelf reports an unknown status.
- Corrective Action
Ensure that the shelf module firmware and ONTAP® software are compatible versions. Find firmware versions at the NetApp technical support web site.
- Syslog Message
Unexpected ESH status of: %d.
- Parameters
status (INT): Unexpected/unknown status code that was received.
