snaprestore.fail events
Creating your file...
Your file is ready
snaprestore.fail.volume.size
- Severity
ALERT
- Description
This message occurs when a SnapRestore® operation on a volume fails due to insufficient space in the target volume to hold the data present in the Snapshot(tm) copy.
- Corrective Action
Resize the target volume to the recommended minimum size.
- Syslog Message
SnapRestore operation failed: volume %s is too small to hold the data present in the Snapshot copy. Minimum size of the target volume required is %s.
- Parameters
volume (STRING): Volume name.
volsize (STRING): Recommended minimum size of the target volume.
