ONTAP EMS reference
snaprestore.fail events
snaprestore.fail EMS events occur when a SnapRestore® operation on a volume fails due to insufficient space in the target volume to hold the data present in the snapshot.
snaprestore.fail.volume.size
Severity
ALERT
This message occurs when a SnapRestore® operation on a volume fails due to insufficient space in the target volume to hold the data present in the snapshot.
Corrective Action
Resize the target volume to the recommended minimum size.
Syslog Message
SnapRestore operation failed: volume %s is too small to hold the data present in the snapshot. Minimum size of the target volume required is %s.
volume (STRING): Volume name.
volsize (STRING): Recommended minimum size of the target volume.
