disk.toomanyspindles events
Creating your file...
Your file is ready
disk.tooManySpindles
- Severity
ALERT
- Description
This message occurs when Data ONTAP® finds more disks present on a platform than the platform actually supports. Additional disks above the support number are ignored. Correct this issue before rebooting the system.
- Corrective Action
Too many disks have been installed. Reconfigure the system to the maximum number of disks supported.
- Syslog Message
Found %d disks, but maximum of %d disks are supported on this system. All additional disks will be ignored. This problem must be resolved before the system is rebooted.
- Parameters
actualSpindle (INT): Actual number of disks configured.
maxSpindle (INT): Maximum number of disks supported on this platform.
