ONTAP EMS reference
disk.toomanyspindles events
disk.tooManySpindles
Severity
ALERT
This message occurs when Data ONTAP® finds more disks present on a platform than the platform actually supports. Additional disks above the support number are ignored. Correct this issue before rebooting the system.
Corrective Action
Too many disks have been installed. Reconfigure the system to the maximum number of disks supported.
Syslog Message
Found %d disks, but maximum of %d disks are supported on this system. All additional disks will be ignored. This problem must be resolved before the system is rebooted.
actualSpindle (INT): Actual number of disks configured.
maxSpindle (INT): Maximum number of disks supported on this platform.
