mgmt.s3 events
mgmt.s3 EMS events occur when ONTAP encounters issues associated with S3 Snapmirror capacity license limits for external object store relationships.
mgmt.s3.sm.license.near.limit
- Severity
NOTICE
- Description
This message occurs when the total cluster-wide logical used size for S3 Snapmirror external object store relationships is near the license capacity limit but does not exceed the limit.
- Corrective Action
To increase the license capacity, install a new license on the cluster. Alternatively, remove some data you are managing.
- Syslog Message
%s.
- Parameters
message (STRING): Capacity warning message for users
mgmt.s3.sm.license.over.limit
- Severity
ERROR
- Description
This message occurs when the total cluster-wide bucket used size for S3 Snapmirror external object store relationships is over the license capacity limit.
- Corrective Action
- Syslog Message
%s.
- Parameters
