mgmt.s3 events
mgmt.s3.sm.license.near.limit
Severity
NOTICE
This message occurs when the total cluster-wide logical used size for S3 Snapmirror external object store relationships is near the license capacity limit but does not exceed the limit.
Corrective Action
To increase the license capacity, install a new license on the cluster. Alternatively, remove some data you are managing.
Syslog Message
%s.
message (STRING): Capacity warning message for users
mgmt.s3.sm.license.over.limit
Severity
ERROR
This message occurs when the total cluster-wide bucket used size for S3 Snapmirror external object store relationships is over the license capacity limit.
Corrective Action
Syslog Message
%s.
