      mgmt.s3 events
mgmt.s3.sm.license.near.limit
- Severity
NOTICE
 - Description
This message occurs when the total cluster-wide logical used size for S3 Snapmirror external object store relationships is near the license capacity limit but does not exceed the limit.
 - Corrective Action
To increase the license capacity, install a new license on the cluster. Alternatively, remove some data you are managing.
 - Syslog Message
%s.
 - Parameters
message (STRING): Capacity warning message for users
mgmt.s3.sm.license.over.limit
- Severity
ERROR
 - Description
This message occurs when the total cluster-wide bucket used size for S3 Snapmirror external object store relationships is over the license capacity limit.
 - Corrective Action
 - Syslog Message
%s.
 - Parameters
