ONTAP EMS reference
sp.eth events
sp.eth EMS events occur when ONTAP encounters issues associated with the Service Processor (SP) or Baseboard Management Controller (BMC) Ethernet switch.
sp.eth.switch.upd.failed
Severity
ERROR
This message occurs when Service Processor (SP) or Baseboard Management Controller (BMC) fails to auto-update the internal Ethernet switch.
Corrective Action
  1. Perform a manual Ethernet Switch update from SP or BMC CLI. 2. If the failures persist, contact NetApp technical support.
Syslog Message
%s Ethernet switch auto-update failed.
sp_type (STRING): SP type
sp.eth.switch.upd.start
Severity
NOTICE
This message occurs when the Service Processor (SP) or Baseboard Management Controller (BMC) starts an internal Ethernet switch auto-update. During the Ethernet switch update, SP or BMC and e0M network connections might be temporarily affected.
Corrective Action
(None).
Syslog Message
%s is starting Ethernet switch auto-update %s.
switch_ver (STRING): Current and bundled switch version.
sp.eth.switch.upd.success
Severity
NOTICE
This message occurs when the Service Processor (SP) or Baseboard Management Controller (BMC) completes an internal Ethernet switch auto-update.
Corrective Action
(None).
Syslog Message
%s Ethernet switch version updated %s.
switch_ver (STRING): Previous and updated switch version.
