configbr.deletefailed events
configbr.deletefailed EMS events occur when an old configuration backup cannot be deleted.
configbr.deleteFailed
- Severity
ERROR
- Description
This message occurs when an old configuration backup cannot be deleted.
- Corrective Action
Ensure that the node is accessible and healthy. If necessary, delete the backup manually with the (privilege: advanced) "system configuration backup delete" command.
- Syslog Message
The %s configuration backup %s on node %s cannot be deleted. Error: '%s'.
- Parameters
type (STRING): Type of backup, either cluster or local.
backup (STRING): Backup file.
node (STRING): Node on which the backup file exists.
reason (STRING): Reason for the error.
