ha.takeoverimpunsync events
ha.takeoverImpUnsync
- Severity
ALERT
- Description
This message occurs when the partner node is down and it is currently impossible to perform a takeover because the takeover node does not have partner NVRAM data.
- Corrective Action
Verify that the interconnect cables are correctly connected between the nodes. Boot the partner node to reestablish the interconnect if it was shut down. If necessary, force a takeover with the '[run node] cf forcetakeover' command. This action might cause data loss if there is NVRAM data on the partner node not written to disk.
- Syslog Message
Takeover of the partner node is impossible due to lack of partner NVRAM data.
- Parameters
(None).
