The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
ha.takeoverimpunsync events
Creating your file...
Your file is ready
ha.takeoverImpUnsync
- Severity
ALERT
- Description
This message occurs when the partner node is down and it is currently impossible to perform a takeover because the takeover node does not have partner NVRAM data.
- Corrective Action
Verify that the interconnect cables are correctly connected between the nodes. Boot the partner node to reestablish the interconnect if it was shut down. If necessary, force a takeover with the '[run node] cf forcetakeover' command. This action might cause data loss if there is NVRAM data on the partner node not written to disk.
- Syslog Message
Takeover of the partner node is impossible due to lack of partner NVRAM data.
- Parameters
(None).
