vsdr.net events
vsdr.net.IPInDiffVserver
- Severity
ERROR
 - Description
This message occurs when the system tries to automatically replicate a logical interface (LIF) in a MetroCluster™ configuration or Vserver DR setup and the IP address of the LIF that is being created already exists in another Vserver.
 - Corrective Action
Change the IP address of the LIF in the other Vserver or remove the LIF so that creation of the LIF succeeds and configuration replication continues.
 - Syslog Message
Cannot create LIF %s with IP address %s in Vserver %s because another LIF with the same IP exists in another Vserver.
 - Parameters
lif (STRING): LIF name.
ipaddr (STRING): IP address of the LIF.
vserver_name (STRING): Vserver name.
vsdr.net.LifIpCollision
- Severity
ERROR
 - Description
This message occurs in an ID-Preserve VserverDR configuration of clustered Data ONTAP®, when a non-SAN LIF created on the source Storage Virtual Machine(SVM) has the same IP address as an iSCSI LIF on the destination SVM.
 - Corrective Action
Assign a unique IP address for the iSCSI LIF on the destination SVM.
 - Syslog Message
An iSCSI LIF is configured in the destination SVM %s with the same IP address (%s) as the source LIF (%s). Assign a unique IP address to the iSCSI LIF (%s) by modifying the LIF on the destination SVM.
 - Parameters
vserver_name (STRING): SVM name.
ip_address (STRING): IP address of the iSCSI LIF on the destination SVM.
source_lif_name (STRING): Source LIF name.
destination_lif_name (STRING): Destination LIF name.
vsdr.net.LifNameCollision
- Severity
ERROR
 - Description
This message occurs in an ID-Preserve VserverDR configuration of clustered Data ONTAP®, when a non-SAN LIF created on the source Storage Virtual Machine(SVM) has the same name as a SAN LIF on the destination SVM.
 - Corrective Action
Assign a unique LIF name for the SAN LIF on the destination SVM.
 - Syslog Message
A SAN LIF is configured in the destination SVM %s with the same name as the source LIF. Assign a unique name to the SAN LIF (%s) by modifying the LIF name on the destination SVM.
 - Parameters
lif_name (STRING): Source and Destination LIF name.
vsdr.net.LifNotReachable
- Severity
ERROR
 - Description
This message occurs when a logical interface (LIF) modify operation is performed on the source cluster without changing the home node and home port, and the LIF placement fails when the configuration is being replicated.
 - Corrective Action
Ensure that the destination cluster has ports that have connectivity to the LIF on the source cluster.
 - Syslog Message
The LIF %s in DR partner Vserver of Vserver %s is not reachable from the local cluster.
 - Parameters
lif (STRING): The LIF name.
vserver_name (STRING): The Vserver name.
vsdr.net.NoPortsInBD
- Severity
ERROR
 - Description
This message occurs when the system tries to automatically replicate a logical interface (LIF) in a MetroCluster™ configuration or Vserver DR setup, and it cannot find any ports in a broadcast domain in a cluster.
 - Corrective Action
Add at least one port to the broadcast domain in the IPspace using the "network port broadcast-domain add-ports" command and then resynchronize the Vserver configuration using the "metrocluster vserver resync" command.
 - Syslog Message
Cannot find ports in broadcast domain %s in IPspace %s for placing LIF %s in Vserver %s.
 - Parameters
broadcast_domain (STRING): The Broadcast domain.
ipspace_name (STRING): The IPspace name.
vsdr.net.NoPortsInIpsOnNode
- Severity
ERROR
 - Description
This message occurs when the system tries to automatically replicate a logical interface (LIF) in a MetroCluster™ configuration or Vserver DR setup, and it cannot find any ports in an IPspace on a particular node.
 - Corrective Action
Add at least one port belonging to the node to the IPspace by using the "network port broadcast-domain add-ports" command and then resynchronize the Vserver configuration using the "metrocluster vserver resync" command.
 - Syslog Message
Cannot find ports in IPspace %s on node %s for placing LIF %s in Vserver %s.
 - Parameters
node_name (STRING): Name of the node to which LIFs could not be replicated.
vsdr.net.NoPortsInIpspace
- Severity
ERROR
 - Description
This message occurs when the system tries to automatically replicate a logical interface (LIF) in a MetroCluster™ configuration or Vserver DR setup, and it cannot find any ports in an IPspace in a cluster.
 - Corrective Action
Add at least one port to the IPspace by using the "network port broadcast-domain add-ports" command and then resynchronize the Vserver configuration using the "metrocluster vserver resync" command.
 - Syslog Message
Cannot find ports in IPspace %s for placing LIF %s in Vserver %s.
 - Parameters
vsdr.net.NoVipPortInIpsNode
- Severity
ERROR
 - Description
This message occurs when the system attempts to replicate a logical interface (LIF) associated with the Virtual IP (VIP) feature to a node where no BGP peer group is available in the target IPspace. This configuration replication functionality is exercised by systems in a MetroCluster(tm).
 - Corrective Action
Use the "network bgp peer-group create" command to create a BGP peer group in the target IPspace on the affected node, and then use the "metrocluster vserver resync" command to recover from the failed replication.
 - Syslog Message
Cannot find a VIP port in IPspace %s on node %s for placing VIP LIF %s in Vserver %s.
 - Parameters
ipspace_name (STRING): IPspace name.
node_name (STRING): Name of the node to which VIP LIFs could not be replicated.
lif (STRING): VIP LIF name.
vsdr.net.NoVipPortInIpspace
- Severity
ERROR
 - Description
This message occurs when the system attempts to replicate a logical interface (LIF) associated with the Virtual IP (VIP) feature in a MetroCluster™ configuration or Vserver DR setup, and the Border Gateway Protocol (BGP) is not configured in the target IPspace.
 - Corrective Action
Use the "network bgp peer-group create" command to create a BGP peer group in the target IPspace, and then use the "metrocluster vserver resync" command to recover from the failed replication.
 - Syslog Message
Cannot find a VIP port in IPspace %s for placing VIP LIF %s in Vserver %s.
 - Parameters
vsdr.net.v6optdisabled
- Severity
ERROR
 - Description
This message occurs in a MetroCluster™ configuration when the system is trying to replicate an IPv6 LIF, but IPv6 is not enabled on the cluster.
 - Corrective Action
Enable IPv6 by using the "network options ipv6 modify -enabled true" command, and then run the "metrocluster vserver resync" command on the source cluster.
 - Syslog Message
Cannot create LIF %s in Vserver %s because IPv6 is not enabled in the cluster.
 - Parameters
vsdr.net.v6optdisabledroute
- Severity
ERROR
 - Description
This message occurs when the system is trying to replicate an IPv6 route in a MetroCluster™ configuration, but IPv6 is not enabled on the cluster.
 - Corrective Action
 - Syslog Message
Cannot create route %s with gateway %s in Vserver %s because IPv6 is not enabled in the cluster.
 - Parameters
route (STRING): Route destination and mask.
gateway (STRING): Gateway of the route.
