ONTAP EMS reference
vsdr.net events
vsdr.net EMS events occur when ONTAP encounters issues associated with logical interface (LIF) replication in MetroCluster or Vserver DR configurations.
vsdr.net.IPInDiffVserver
Severity
ERROR
This message occurs when the system tries to automatically replicate a logical interface (LIF) in a MetroCluster™ configuration or Vserver DR setup and the IP address of the LIF that is being created already exists in another Vserver.
Corrective Action
Change the IP address of the LIF in the other Vserver or remove the LIF so that creation of the LIF succeeds and configuration replication continues.
Syslog Message
Cannot create LIF %s with IP address %s in Vserver %s because another LIF with the same IP exists in another Vserver.
lif (STRING): LIF name.
ipaddr (STRING): IP address of the LIF.
vserver_name (STRING): Vserver name.
vsdr.net.LifIpCollision
Severity
ERROR
This message occurs in an ID-Preserve VserverDR configuration of clustered Data ONTAP®, when a non-SAN LIF created on the source Storage Virtual Machine(SVM) has the same IP address as an iSCSI LIF on the destination SVM.
Corrective Action
Assign a unique IP address for the iSCSI LIF on the destination SVM.
Syslog Message
An iSCSI LIF is configured in the destination SVM %s with the same IP address (%s) as the source LIF (%s). Assign a unique IP address to the iSCSI LIF (%s) by modifying the LIF on the destination SVM.
vserver_name (STRING): SVM name.
ip_address (STRING): IP address of the iSCSI LIF on the destination SVM.
source_lif_name (STRING): Source LIF name.
destination_lif_name (STRING): Destination LIF name.
vsdr.net.LifNameCollision
Severity
ERROR
This message occurs in an ID-Preserve VserverDR configuration of clustered Data ONTAP®, when a non-SAN LIF created on the source Storage Virtual Machine(SVM) has the same name as a SAN LIF on the destination SVM.
Corrective Action
Assign a unique LIF name for the SAN LIF on the destination SVM.
Syslog Message
A SAN LIF is configured in the destination SVM %s with the same name as the source LIF. Assign a unique name to the SAN LIF (%s) by modifying the LIF name on the destination SVM.
lif_name (STRING): Source and Destination LIF name.
vsdr.net.LifNotReachable
Severity
ERROR
This message occurs when a logical interface (LIF) modify operation is performed on the source cluster without changing the home node and home port, and the LIF placement fails when the configuration is being replicated.
Corrective Action
Ensure that the destination cluster has ports that have connectivity to the LIF on the source cluster.
Syslog Message
The LIF %s in DR partner Vserver of Vserver %s is not reachable from the local cluster.
lif (STRING): The LIF name.
vserver_name (STRING): The Vserver name.
vsdr.net.LifPlacedOnDifferentIfgroup
Severity
NOTICE
This message occurs when a logical interface (LIF) is placed on a different ifgroup than the source during replication. These ifgroups could be in different broadcast domains.
Corrective Action
(None).
Syslog Message
LIF %s in Vserver %s was placed on a different ifgroup (source: %s). Different ifgroups could be in different broadcast domains.
source_ifgroup (STRING): The ifgroup name of the LIF on the source cluster.
vsdr.net.LifPlacedOnDifferentVlanTag
Severity
NOTICE
This message occurs when a logical interface (LIF) is placed on a VLAN port with a different VLAN tag than the source during replication. Different VLAN tags may indicate different broadcast domains.
Corrective Action
(None).
Syslog Message
LIF %s in Vserver %s was placed on a port with a different VLAN tag (source tag: %s). Different VLAN tags may indicate different broadcast domains.
source_vlan_tag (STRING): The VLAN tag of the LIF on the source cluster.
vsdr.net.NoPortsInBD
Severity
ERROR
This message occurs when the system tries to automatically replicate a logical interface (LIF) in a MetroCluster™ configuration or Vserver DR setup, and it cannot find any ports in a broadcast domain in a cluster.
Corrective Action
Add at least one port to the broadcast domain in the IPspace using the "network port broadcast-domain add-ports" command and then resynchronize the Vserver configuration using the "metrocluster vserver resync" command.
Syslog Message
Cannot find ports in broadcast domain %s in IPspace %s for placing LIF %s in Vserver %s.
broadcast_domain (STRING): The Broadcast domain.
ipspace_name (STRING): The IPspace name.
vsdr.net.NoPortsInIpsOnNode
Severity
ERROR
This message occurs when the system tries to automatically replicate a logical interface (LIF) in a MetroCluster™ configuration or Vserver DR setup, and it cannot find any ports in an IPspace on a particular node.
Corrective Action
Add at least one port belonging to the node to the IPspace by using the "network port broadcast-domain add-ports" command and then resynchronize the Vserver configuration using the "metrocluster vserver resync" command.
Syslog Message
Cannot find ports in IPspace %s on node %s for placing LIF %s in Vserver %s.
node_name (STRING): Name of the node to which LIFs could not be replicated.
vsdr.net.NoPortsInIpspace
Severity
ERROR
This message occurs when the system tries to automatically replicate a logical interface (LIF) in a MetroCluster™ configuration or Vserver DR setup, and it cannot find any ports in an IPspace in a cluster.
Corrective Action
Add at least one port to the IPspace by using the "network port broadcast-domain add-ports" command and then resynchronize the Vserver configuration using the "metrocluster vserver resync" command.
Syslog Message
Cannot find ports in IPspace %s for placing LIF %s in Vserver %s.
vsdr.net.NoVipPortInIpsNode
Severity
ERROR
This message occurs when the system attempts to replicate a logical interface (LIF) associated with the Virtual IP (VIP) feature to a node where no BGP peer group is available in the target IPspace. This configuration replication functionality is exercised by systems in a MetroCluster(tm).
Corrective Action
Use the "network bgp peer-group create" command to create a BGP peer group in the target IPspace on the affected node, and then use the "metrocluster vserver resync" command to recover from the failed replication.
Syslog Message
Cannot find a VIP port in IPspace %s on node %s for placing VIP LIF %s in Vserver %s.
ipspace_name (STRING): IPspace name.
node_name (STRING): Name of the node to which VIP LIFs could not be replicated.
lif (STRING): VIP LIF name.
vsdr.net.NoVipPortInIpspace
Severity
ERROR
This message occurs when the system attempts to replicate a logical interface (LIF) associated with the Virtual IP (VIP) feature in a MetroCluster™ configuration or Vserver DR setup, and the Border Gateway Protocol (BGP) is not configured in the target IPspace.
Corrective Action
Use the "network bgp peer-group create" command to create a BGP peer group in the target IPspace, and then use the "metrocluster vserver resync" command to recover from the failed replication.
Syslog Message
Cannot find a VIP port in IPspace %s for placing VIP LIF %s in Vserver %s.
vsdr.net.v6optdisabled
Severity
ERROR
This message occurs in a MetroCluster™ configuration when the system is trying to replicate an IPv6 LIF, but IPv6 is not enabled on the cluster.
Corrective Action
Enable IPv6 by using the "network options ipv6 modify -enabled true" command, and then run the "metrocluster vserver resync" command on the source cluster.
Syslog Message
Cannot create LIF %s in Vserver %s because IPv6 is not enabled in the cluster.
vsdr.net.v6optdisabledroute
Severity
ERROR
This message occurs when the system is trying to replicate an IPv6 route in a MetroCluster™ configuration, but IPv6 is not enabled on the cluster.
Corrective Action
Syslog Message
Cannot create route %s with gateway %s in Vserver %s because IPv6 is not enabled in the cluster.
route (STRING): Route destination and mask.
gateway (STRING): Gateway of the route.
