The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
exports.dns events
Creating your file...
Your file is ready
exports.dns.config
- Severity
ERROR
- Description
This message occurs when a name services lookup request finds that DNS is configured as an ns-switch source for hosts, but DNS is not configured for the Vserver. Name services lookups using DNS do not function.
- Corrective Action
Check the ns-switch sources for hosts database configured for the Vserver using "vserver services name-service ns-switch show -database hosts" and the DNS configuration for the Vserver using "vserver services name-service dns show". Either remove DNS as an ns-switch source, or configure DNS using the "vserver services name-service dns create" command.
- Syslog Message
DNS is configured as a ns-switch source for hosts, but the DNS configuration is not found for Vserver "%s".
- Parameters
vserver (STRING): Name of the Vserver on which the problem is occurring.
