scsiblade.vol events
scsiblade.vol EMS events occur when ONTAP encounters issues associated with SAN volume initialization.
scsiblade.vol.init.failed
- Severity
EMERGENCY
- Description
This message occurs when SAN initialization fails for the specified volume on this node. Access to LUNs contained in this volume from this node is not available.
- Corrective Action
Reboot the node by performing a planned takeover and giveback.
- Syslog Message
SAN configuration in Vserver %s failed to initialize for volume with MSID %llu. Access to LUNs contained in this volume from this node is not available.
- Parameters
vserver (STRING): Name or UUID of the Vserver.
volumeMSID (LONGINT): MSID of the volume.
errorType (LONGINT): Error type.
errorCode (LONGINT): Error code.
scsiblade.vol.lun.stale.map
- Severity
ERROR
- Description
This message occurs when a volume lookup operation fails because the volume is not found. This is an indication that there might be stale LUN maps associated with the volume.
- Corrective Action
Contact NetApp technical support for assistance with the (privilege: diag) "lun stale-map" commands.
- Syslog Message
Could not lookup the volume with MSID '%llu' in Vserver '%s'. This is an indication that there might be stale lun maps associated with the volume.
- Parameters
volume (LONGINTHEX): Volume identifier.
