scsiblade.vol events
scsiblade.vol.init.failed
Severity
EMERGENCY
This message occurs when SAN initialization fails for the specified volume on this node. Access to LUNs contained in this volume from this node is not available.
Corrective Action
Reboot the node by performing a planned takeover and giveback.
Syslog Message
SAN configuration in Vserver %s failed to initialize for volume with MSID %llu. Access to LUNs contained in this volume from this node is not available.
vserver (STRING): Name or UUID of the Vserver.
volumeMSID (LONGINT): MSID of the volume.
errorType (LONGINT): Error type.
errorCode (LONGINT): Error code.
scsiblade.vol.lun.stale.map
Severity
ERROR
This message occurs when a volume lookup operation fails because the volume is not found. This is an indication that there might be stale LUN maps associated with the volume.
Corrective Action
Contact NetApp technical support for assistance with the (privilege: diag) "lun stale-map" commands.
Syslog Message
Could not lookup the volume with MSID '%llu' in Vserver '%s'. This is an indication that there might be stale lun maps associated with the volume.
volume (LONGINTHEX): Volume identifier.
