ONTAP EMS reference
dbs.bulk events
dbs.bulk EMS events occur when a Distributed Block Store (DBS) event related to bulk volume operations, such as backups, restores, Snapshot copies, or cloning, occurs.
dbs.bulk.op
Severity
NOTICE
This message occurs when a Distributed Block Store (DBS) event related to bulk volume operations such as backups, restores, making of Snapshot copies, or cloning occurs. If the original distributed block store event specifies multiple drives, then an EMS event is generated for each drive.
Corrective Action
(None).
Syslog Message
A DBS event occurred, event %s, type %s, service %u, node %u/%s, drive %u/%s, eventID %u.
evtMessage (STRING): Description of the DBS event, including context details.
evtType (STRING): Type of the original DBS event.
serviceID (INT): Service ID that identifies the associated DBS service. It is "0" if there is no associated service.
nodeID (INT): Node ID number of the associated node. It is "0" if there is no associated node.
nodeUuid (STRING): Generated Universal Unique Identifier (UUID) of the associated node. It displays zeroes if there is no associated node.
driveID (INT): Drive ID number of the associated drive. It is "0" if there is no associated drive.
driveUuid (STRING): Generated UUID of the associated drive. It displays zeroes if there is no associated drive.
evtID (INT): DBS event ID number.
evtDetails (STRING): Specific details of the DBS event. It displays as a string, in JSON format, or is empty.
