The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
mcc.ipspace events
Creating your file...
Your file is ready
mcc.ipspace.not.found
- Severity
ERROR
- Description
This message occurs when the IPspace is not found in a MetroCluster(tm) configuration while replicating the object store configuration. Until this is resolved, some MetroCluster and FabricPool operations will fail.
- Corrective Action
Create the missing MetroCluster IPspace. The configuration replication task will be completed automatically.
- Syslog Message
Object store "%s" configuration replication failed because IPspace "%s" was not found in cluster "%s".
- Parameters
object_store_name (STRING): Name of the object store.
ipspace_name (STRING): Name of the IPspace.
cluster_name (STRING): Name of the cluster.
