ONTAP EMS reference
mcc.sb events
mcc.sb EMS events occur when ONTAP encounters issues associated with dump or restore operations during MetroCluster switchback.
mcc.sb.abort.dump
Severity
NOTICE
This message occurs when dump/restore is aborted during a MetroCluster switchback operation.
Corrective Action
(None).
Syslog Message
Dump/restore operations were aborted because %s is in progress.
sb (STRING): Describes whether a MetroCluster switchback operation is progress.
mcc.sb.veto.repl
Severity
NOTICE
This message occurs when an MetroCluster(tm) switchback is vetoed by a critical replication transfer (for example, volume move in the cutover phase).
Corrective Action
Either abort the replication transfer that is preventing the MetroCluster switchback from being completed, retry the MetroCluster switchback operation with the '-override-vetoes true' option, or wait for the transfer to finish.
Syslog Message
Could not complete switchback because a replication transfer with UUID %s is in progress.
transferId (STRING): UUID of the SnapMirror® replication transfer that vetoed the MetroCluster switchback.
