ONTAP EMS reference
monitor.nvramlowbatteries events
monitor.nvramlowbatteries EMS events occur when ONTAP encounters issues associated with NVRAM batteries power levels.
monitor.nvramLowBatteries
Severity
EMERGENCY
This message occurs when the NVRAM batteries are at a dangerously low power level.
Corrective Action
Replace the NVRAM batteries.
Syslog Message
NVRAM batteries are dangerously low.
(None).
monitor.nvramLowBatteries.notice
Severity
NOTICE
This message occurs when a low batteries situation exists. The timeout[123] values are duplicated as a convenience for the Syslog message, which prints out the value three times.
Corrective Action
Syslog Message
If the NVRAM batteries are dangerously low, the system shuts down automatically every %d hours to encourage you to replace them. If you reboot the system it will run for another %d hours before shutting down.
timeout1 (INT): Timeout value.
timeout2 (INT): Timeout value.
timeout3 (INT): Timeout value.
