monitor.nvramlowbatteries events
monitor.nvramLowBatteries
Severity
EMERGENCY
This message occurs when the NVRAM batteries are at a dangerously low power level.
Corrective Action
Replace the NVRAM batteries.
Syslog Message
NVRAM batteries are dangerously low.
(None).
monitor.nvramLowBatteries.notice
Severity
NOTICE
This message occurs when a low batteries situation exists. The timeout[123] values are duplicated as a convenience for the Syslog message, which prints out the value three times.
Corrective Action
Syslog Message
If the NVRAM batteries are dangerously low, the system shuts down automatically every %d hours to encourage you to replace them. If you reboot the system it will run for another %d hours before shutting down.
timeout1 (INT): Timeout value.
timeout2 (INT): Timeout value.
timeout3 (INT): Timeout value.
