monitor.nvramlowbatteries events
Creating your file...
Your file is ready
monitor.nvramLowBatteries
- Severity
EMERGENCY
- Description
This message occurs when the NVRAM batteries are at a dangerously low power level.
- Corrective Action
Replace the NVRAM batteries.
- Syslog Message
NVRAM batteries are dangerously low.
- Parameters
(None).
monitor.nvramLowBatteries.notice
- Severity
NOTICE
- Description
This message occurs when a low batteries situation exists. The timeout[123] values are duplicated as a convenience for the Syslog message, which prints out the value three times.
- Corrective Action
- Syslog Message
If the NVRAM batteries are dangerously low, the system shuts down automatically every %d hours to encourage you to replace them. If you reboot the system it will run for another %d hours before shutting down.
- Parameters
timeout1 (INT): Timeout value.
timeout2 (INT): Timeout value.
timeout3 (INT): Timeout value.
