The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
rlib.duplicate events
Creating your file...
Your file is ready
rlib.duplicate.ip.detected
- Severity
ERROR
- Description
This message occurs when an interconnect link IP address on this node has a conflict with an IP address on another node in the cluster.
- Corrective Action
Reboot either this node or the other node reported in this event, while making sure that all interconnect links on the two nodes are connected, up, and operational.
- Syslog Message
Interconnect link IP address %s on this node (System ID %d) is also in use by another node (System ID %d) in the cluster.
- Parameters
dupIP (STRING): Conflicting IP address.
localSysid (LONGINT): System ID of the local node.
remoteSysid (LONGINT): System ID of the remote node.
