ONTAP EMS reference
sfu.badbridgeshelfconfig events
sfu.badBridgeShelfConfig
Severity
ALERT
This message occurs when the disk shelf firmware update aborts because it cannot contact the two peer FC-to-SAS bridges.
Corrective Action
Make sure that the storage controller is correctly cabled to the two peer FC-to-SAS bridges and that the bridges are correctly cabled to the SAS disk shelves. Then retry the (advanced privilege) "storage shelf firmware update" command.
Syslog Message
Firmware update aborted on disk shelf %s.shelf%d module %s. Unable to contact two peer FC-to-SAS bridges.
channelName (STRING): Name of the adapter port or switch port of the disk shelf that aborted the firmware update.
shelfId (INT): ID of the disk shelf that aborted the firmware update.
module (STRING): Module that aborted the firmware update.
