ONTAP EMS reference
crypto.export events
crypto.export.failed
Severity
ALERT
This message occurs when the export of a cryptographic key fails.
Corrective Action
This message might be seen when attempting to create an encrypted volume. Contact NetApp technical support if further attempts to create the encrypted volume fail.
Syslog Message
ERROR: Export of key with key ID %s failed. Additional information: %s.
key_id (STRING): Key ID for the cryptographic key.
msg (STRING): Associated failure message.
