ONTAP EMS reference
sfu.partnerupdatetimeout events
sfu.partnerupdatetimeout EMS events occur in a high-availability (HA) configuration in which an HA partner was downloading disk shelf firmware and the download has timed out.
sfu.partnerUpdateTimeout
Severity
INFORMATIONAL
This message occurs in a high-availability (HA) configuration in which an HA partner was downloading disk shelf firmware and the download has timed out. The system resumes enclosure services monitoring.
Corrective Action
Verify that the HA interconnect is operational and then retry the (advanced privilege) "storage shelf firmware update" command.
Syslog Message
Waited %d minutes for partner shelf firmware update. Resuming enclosure services.
minutes (INT): Duration of the partner update timeout, in minutes.
