ONTAP EMS reference
sfu.downloadsummaryerrors events
sfu.downloadsummaryerrors EMS events occur when a disk shelf firmware update completes without successfully downloading to all shelves it attempted.
sfu.downloadSummaryErrors
Severity
ERROR
This message occurs when a disk shelf firmware update completes without successfully downloading to all shelves it attempted.
Corrective Action
Issue the (advanced privilege) "storage shelf firmware update" command again.
Syslog Message
Shelf firmware updated on %d %s, failed to update on %d %s.
successCount (INT): Number of shelves successfully updated.
pluralShelf (STRING): Shelf or Shelves.
failedCount (INT): Number of shelves that failed to update.
pluralShelfFailed (STRING): Shelf or Shelves.
