sfu.downloadsummaryerrors events
sfu.downloadsummaryerrors EMS events occur when a disk shelf firmware update completes without successfully downloading to all shelves it attempted.
sfu.downloadSummaryErrors
- Severity
ERROR
- Description
This message occurs when a disk shelf firmware update completes without successfully downloading to all shelves it attempted.
- Corrective Action
Issue the (advanced privilege) "storage shelf firmware update" command again.
- Syslog Message
Shelf firmware updated on %d %s, failed to update on %d %s.
- Parameters
successCount (INT): Number of shelves successfully updated.
pluralShelf (STRING): Shelf or Shelves.
failedCount (INT): Number of shelves that failed to update.
pluralShelfFailed (STRING): Shelf or Shelves.
