The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
sfu.downloadsummaryerrors events
Creating your file...
Your file is ready
sfu.downloadSummaryErrors
- Severity
ERROR
- Description
This message occurs when a disk shelf firmware update completes without successfully downloading to all shelves it attempted.
- Corrective Action
Issue the (advanced privilege) "storage shelf firmware update" command again.
- Syslog Message
Shelf firmware updated on %d %s, failed to update on %d %s.
- Parameters
successCount (INT): Number of shelves successfully updated.
pluralShelf (STRING): Shelf or Shelves.
failedCount (INT): Number of shelves that failed to update.
pluralShelfFailed (STRING): Shelf or Shelves.
