ONTAP EMS reference
virtual.limits events
virtual.limits EMS events occur when ONTAP encounters issues associated with process virtual memory limit calculations.
virtual.limits.disabled
Severity
INFORMATIONAL
This message occurs when the process virtual memory limit calculations are disabled on a given node. The virtual memory calculations are explicitly disabled by setting the boot argument "bootarg.engage_vss_limit=false".
Corrective Action
(None).
Syslog Message
Virtual memory limit calculations are disabled on node %s.
node (STRING): Name of the node where the calculations are disabled.
virtual.limits.proc
Severity
INFORMATIONAL
This message occurs when the process virtual limit is overridden by the /mroot/etc/cluster_config/vsz_override file. An entry in this file indicates that the default virtual size of a process needed to be overridden.
Corrective Action
(None).
Syslog Message
Virtual memory limit for process %s on node %s overridden to %llu.
process (STRING): Process that required the override
node (STRING): Node name where the file was updated.
size (LONGINT): New virtual size, in bytes.
