application.volume events
application.volume.removed
Severity
ERROR
This message occurs when an application is destroyed, but a member volume was not deleted after an error was was encountered. This volume is no longer associated with the application and must be deleted manually.
Corrective Action
Delete the volume using the "volume delete" command.
Syslog Message
Failed to destroy member volume %s in Vserver %s during an application destroy operation. The volume must be deleted manually. The volume was previously associated with an application with UUID %s.
volumeName (STRING): Name of the volume.
vserver (STRING): Vserver containing the volume.
applicationUUID (STRING): UUID of the application.
