application.volume events
Creating your file...
Your file is ready
application.volume.removed
- Severity
ERROR
- Description
This message occurs when an application is destroyed, but a member volume was not deleted after an error was was encountered. This volume is no longer associated with the application and must be deleted manually.
- Corrective Action
Delete the volume using the "volume delete" command.
- Syslog Message
Failed to destroy member volume %s in Vserver %s during an application destroy operation. The volume must be deleted manually. The volume was previously associated with an application with UUID %s.
- Parameters
volumeName (STRING): Name of the volume.
vserver (STRING): Vserver containing the volume.
applicationUUID (STRING): UUID of the application.
