      application.volume events
application.volume.removed
- Severity
ERROR
 - Description
This message occurs when an application is destroyed, but a member volume was not deleted after an error was was encountered. This volume is no longer associated with the application and must be deleted manually.
 - Corrective Action
Delete the volume using the "volume delete" command.
 - Syslog Message
Failed to destroy member volume %s in Vserver %s during an application destroy operation. The volume must be deleted manually. The volume was previously associated with an application with UUID %s.
 - Parameters
volumeName (STRING): Name of the volume.
vserver (STRING): Vserver containing the volume.
applicationUUID (STRING): UUID of the application.
