ONTAP EMS reference
application.volume events
application.volume EMS events occur when an application is destroyed, but a member volume was not deleted after an error was encountered.
application.volume.removed
Severity
ERROR
This message occurs when an application is destroyed, but a member volume was not deleted after an error was encountered. This volume is no longer associated with the application and must be deleted manually.
Corrective Action
Delete the volume using the "volume delete" command. For ASA r2, contact NetApp technical support for assistance to resolve this internal error.
Syslog Message
Fails to destroy member volume %s in storage virtual machine %s during an application destroy operation. The volume must be deleted manually. The volume was previously associated with an application with UUID %s.
volumeName (STRING): Name of the volume.
vserver (STRING): Storage virtual machine (SVM) containing the volume.
applicationUUID (STRING): Universal unique identifier (UUID) of the application.
